The F2833x microcontrollers have an I2C module and it uses GPIO32 and GPIO33 as SDA and SCL signals. However, the Hardware Board Configuration element of the F2833x targets (SimCoder) doesn't not have an I2C configuration option at the GPIO32 and GPIO33 pins (they only have digital input and digital output). How can I configure the device to able to use the I2C module of the microcontroller?
I have also seen there is no I2C elements as for SPI and SCI.
Regards
Javier
