Does anyone know how to change the frequency of the sine source mid simulation? It is not a runtime variable.
There are a couple methods.
The most robust method is to use a DC source behind a resetting integrator that you then convert to a sine wave. There are plenty of examples of this circuit setup in the motor control examples.
