I am building a dual active bridge model in PSIM. I am wondering are there any built-in blocks that can achieve the variable phase shift PWM signal? (like the block "Variable Time/Transport Delay" in MATLAB/Simulink)
Thank you.
JZ
You can accomplish that using the Monostable block:
