Hi Augusto,
I have two MCP4922 ICs that implement four DAC signals on the SPI interface of the Sim code DSP F28335?There are examples to refer to? Program and hardware fig.
Thank you
Yes, there is an example for SPI use in the examples\simcoder\f28335.
Also please refer to the simcoder user manual and to the SPI tutorial pdf both from the help menu for further reading.
After checking the post I remember I was once having the same question when I got the answer from here only. You may sometimes face gmail server error 007 which can be easily fixed.
