Is it normal for PSIM to use several gigs of memory when using the SimCoder blocks?
Task manager shows that my Simview/graphs are only using a couple hundred megs but "PSIM Doc" takes up almost 7 gigs of memory after simulation. This is not the case when I do not use Simcoder blocks.
0.4 second simulation at 5e-8, print step 20.
Thank you any help.
