I'm trying to use the Traction Motor system available in the Design Suites section of PSIM. When I do the initial run, all the parameters that I have input gets updated into the System Parameters text file. However, when I try doing the same later on (after I have relaunched PSIM), I loose that ability, and whatever I change in the interface and select the "Update Parameter File" button, it does not get reflected into the actual text file - it stays the same.
