iam working on mppt with using particle swarm optimisation (PSO) , I have found a three examples for three type of mppt however , there is no example on PSO . I will implement the PSO using C-block . Any advice.
the c block or the dll will be the best thing to do.
if you place a ZOH in front of the c block the block will execute at that rate independent of the timestep.
Actually, I used so many networks, So I have some proper knowledge about it, So for that, I have some different tricks which will be fine for you all. Also, I have install iTunes on Windows 10, by this, you will know how windows10 will work for it.
