Hello, I am missing the inverters folder in PSIM example. I need deadtime.sch file which is usually present in the Inverter folder of PSIM example. If anyone has that folder please share it.
This file usually lives in the "examples\other"
If you are using PSIM v11 or higher you can go to help-> search help and type in deadtime and it will find it for you.
See attached file.
