Bad contact interface TYPE 7, node to surface
Updated by Altair Forum User
Hi ,
I'm doing a contact interface between a surface and a solid. The contact interface /INTER/TYPE 7 is used for the contact node to surface:
/INTER/TYPE7/3
pro_yarn
# Slav_id Mast_id Istf Ithe Igap Ibag Idel Icurv Iadm
10 19 0 0 0 0 0 0 0
# Fscalegap GAP_MAX Fpenmax
0 0 0
# Stmin Stmax %mesh_size dtmin Irem_gap
0 0 0 0 0
# Stfac Fric Gapmin Tstart Tstop
0 .2 .014 0 0
# IBC Inacti VisS VisF Bumult
000 0 0 0 0
# Ifric Ifiltr Xfreq Iform sens_ID
0 0 0 0 0
The value of Gap_min is choised according to the recommended value of the radioss solver:
** WARNING IN INTERFACE GAP
DESCRIPTION :
-- INTERFACE ID : 3
-- INTERFACE TITLE : pro_yarn
INPUT GAP 0.5000000000000E-01
HOWEVER GAP IS RECOMMENDED TO BE LESS THAN 0.1408760900333E-01
The result shows visually a bad contact:
Can Someone please help me to improve this contact pls?
1 - 2 of
21
Gapmin is computed based on your Igap choice. If nothing is specified a default value is computed as minmum,.
From your warning message, change the gapmin to 0.14e-1 and try again.
Try with Istiff=4 and Inacti=6 for penetration.
Regads
Rahul R
