How to evenly apply a 100N force on a 50mm square surface as a pressure on hypermesh??
Go to BC's tab in optistruct user interface, then create pressure. Here you can enter the pressure magnitude, select the nodes of face on which pressure has to be applied. Keep load type as PLOAD 4.
Hi Prakash,
I have a question.
Considering I have 100Kg applied on a surface of 1m^2. I have a pressure of 100 kg/m^2=981N/m^2=9,81*10^-4 MPa.
The total number of elements is 200 so each one is 5mm^2.
Why have I to divide the total pressure by the total number of elements??
To obtain the pressure on each element I guess I have to multiply the pressure (9,81*10^4 MPa) to the area of each element.
Or not? Sorry I'm quite confused, I don't understand why I have to divide the pressure by the total number of elements.
thank you.
@Kenji First calculate the pressure you want to apply (P= Force/ Area) Then select the plates and get the number of elements in that area, Say total number of elements is N in your plate. Divide the Pressure per element (P/N). This is the pressure applied on each element. Go to Pressure panel>> Enter the value (which is P/N) and provide the direction.
@Kenji
Hi, Prakash Pagadala: are you sure on you write ? I think it's WRONG to divide the calculated pressure per elements number !!!
Please check & correct it!!!
@Q.Nguyen-Dai
Sorry I couldn't be able to delete the tag...so, how is it the correct way to calculate pressure on each element?
Thank you
Not sure in what context I replied that. I have noted that I included P/N... I have removed the reply to avoid confusion and I will post after going through it again
Hi @Staedtlerp Sorry for the confusion,
I miscalculated. the pressure on the element face is distributed to the corner nodes (using shape function)
anyways, It shouldn't be divided by the element number. to make it easy, you can select the surface on which you want to apply the pressure.
Prakash Pagadala
Thank you very much. I think I'll do in this way, selecting the surface at which elements are associated. But I have a question: on the tutorial 'Composite optimization of a skateboard with Optistruct', pag. 13, how are calculated pressures? It seems that the pressure is divided by the total number of elements.
@Staedtlerp
I will check with the author regarding that.
Prakash Pagadala Thank you very much. I think I'll do in this way, selecting the surface at which elements are associated. But I have a question: on the tutorial 'Composite optimization of a skateboard with Optistruct', pag. 13, how are calculated pressures? It seems that the pressure is divided by the total number of elements.
NEVER!
Prakash Pagadala, @Staedtlerp
Agree.. I corrected my statement. it shouldn't be divided. I am still not clear what P/N was in my previous reply. Anyways. theoretically, the pressure is distributed to the nodes on the element face. Based on this one can conclude.
@Q.Nguyen-Dai perfect and clear! thank you so much. I guess it could be a mistake in the tutorial that I mentioned.
Thank you very much/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
Prakash Pagadala thank you so much/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20'> Probably I made a mistake reading and studying the tutorial, but It is better to control to avoid misunderstandings/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20'>
/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'> luck
Found a neat trick to apply Bearing pressure on any bearing seat faces.
1. Export the solver deck as FEM file to new folder
2. import the Solver deck in Simlab.
3. Create a solution on static.
4. in forces option we find the bearing pressure dialog.(Select the faces and define the X and Y components of the forces in the dialogue.)
5. Re export the file as FEM and import in HM.
Please find an easier way to do this and comment. Didn't find an easier way to do this.
