Beam End Releases
I am trying to perform a 1D beam element analysis on a formula student race car. I need help regarding the application of beam end releases at the suspension nodes.
Can someone confirm this setup -
Node 1 ie. pin a = 456, node 2 ie pin b =0 - for simulating the a arm with a ball joint is correct or not?
With this, I am unable to get the rocker(bell crank to rotate).
Thank you
How the load is coming to the element and what type of load is it?
Is it possible to share the model file?
0 -
Altair Forum User said:
I have sent the file to you using the secure file transfer link.
0 -
Thank you for the answer sir. That was helpful.
Thank you
Amogh Taraikar
Chassis Team
UTA Racing
0 -
I am trying to achieve thee same thing but in my case the elements break into different pieces and I cant figure out the issue, I am still new to HyperWorks so any help will truly be appreciated.
Thank you.
