Hi all,
8 errors written but not written what are the errors in RADIOSS. is there anyone who faced this issue?
Error is No restart file.
In the folder please search for file_name_0000.out file which will list the errors n the model.
Please share the same.
I am new to RADIOSS.
I tried to run the solver but got error of 'no restart file'.
how do i solve this?
thanks!
Due to some modelling error RADIOSS was not able to create the restart file for this run.
Please check the starter out (_0000.out) file which will list the error. If you can share the starter out file we can help you to solve this.
here is my output file.
Hi, Please reattach the file. Not able to download from the above link.
This seems like an error in header card defined in the model.
From Analysis>>Control cards>> select headercard and keep the values to 1 as shown below and try running.
If the issue still persist please share the model file.
i'll try it.
Hi I'm Syafiq,
I just started using radioss, but I have the same issue which is no restart file.
Can someone help me with this? Your help is much appreciated.
Hi Syafiq,
your model is unable to run because of the error:
ERROR ID : 1109 ** ERROR IN TH DESCRIPTION : -- THGROUP ID : 1 -- THGROUP TITLE : RAIL NO TH VARIABLE DEFINED
There is no variable defined for output request. The default output requests are defined by entering DEF in the Data: Var table.
Thank you sir Ivan, I'll try
Hi beloved members,
I'm still new here, and i just started using HyperCrash, and i'm trying the bumper crash analysis tutorial, but it fails to run the simulation for there's too many errors. Can somebody help me with this? I have no idea on how to read and solve the errors. Your help is much appreciated.
Thank you.
Use Tools>Model Checker>RadiossBlock to find modeling errors.
https://insider.altairhyperworks.com/wp-content/uploads/2017/09/T-T-1248-HyperMesh-Model-Checker.pdf
Components 1-7 were not assigned Part card image, material and property. No simulation controls were defined (run time, output frequency and requests)- those can be quickly set up with Utility>Engine File Assistant. https://altairuniversity.com/wp-content/uploads/2017/05/EngineFileAssistant.pdf
Thank you so much sir Ivan. You are my hero.
Hi sir Ivan,
I really need your help, i'm trying to run a modal analysis on a disk brake, but there are some errors that I couldn't understand.
Thank you so much.
both models have the same issue:
*** ERROR # 2023 *** ADAMS MNF file creation requires DTI,UNITS card.
You need to add DTI UNITS card. Go to Control cards>DTI_UNITS> input the same unit system which you have used for modeling and run the analysis.
Thank you so much sir. Much appreciated
Sorry to bother you, I've so much error that I couldn't understand, I really need your help.
The error above has been solved, but there are still some errors when I'm triying to run the analysis.
Your help is much appreciated. Thank you so much.
Glad to help.
*** See next message about line 10802 from file: C:/Users/Hicom/Desktop/modal 2/test 3/test 1/test 2 'CTRIA3 10242 0 10725 1967 1968' This line was interpreted as: 10802:CTRIA3, 10242, 0, 10725, 1967, 1968 *** ERROR # 1000 *** in the input data: Incorrect data in field # 3. Expected INT > 0 or blank, found INTEGER (0).
the '0' in the 3rd column of the CTRIA3 definition indicates that at least some elements have no PIDs (property) assigned. Please check in HM if you have correct references from the comps (or elements) to the props.
You have in HM two possibilities to reference the proper property to your CTRIA3 elements:
1) (recommended): Assign the property collector (PSHELL) to the component collector your CTRIA3 elements are in
2) Assign the property collector (PSHELL) directly to your CTRIA3 elements.
Use Tools>Model Checker>Optistruct to find modeling errors.
I've run the model checker, and it says no error, but I still can't run the analysis.
I think I messed up my model, can you please check my model?
Sorry to bother you so much & thanks a lot sir.
There is a warning due to material properties:
*** WARNING # 1030 Consistency requirement E=2G(1+NU) violated (by 18%). Different values of G (either provided or inferred depending on element type) will be used. See the Material Property Checks section of the documentation.
There are many errors due to bad element quality:
Element # 6859, element type QUAD4. WARNING - Outside of recommended range: Vertex Angle = 174.48 upper limit = 165.00
I could remesh the model, but you would not learn how to do it yourself if I did it for you. I just corrected the worst elements so the model is able to run. You should remesh the model using the these tools:
There are some great learning materials from Altair university- Practical Aspects of Finite Element Simulation is a good starting point.
https://altairuniversity.com/free-ebooks-2/
Check the following Youtube channels:
Altair University
Altair India Student Contest
ELEATION By Apoorv Bapat
Thank you so much sir,
I'll try my best to learn and do it myself,
Thanks again sir, hope you have a beautiful day today.
Hi, This seems like an error in header card defined in the model. From Analysis>>Control cards>> select headercard and keep the values to 1 as shown below and try running. <?xml version="1.0" encoding="UTF-8"?> If the issue still persist please share the model file.
Thanks a lot for sharing this info. but I cannot find where this headcard is.
is it in ENG_RUN ? I could not find it in the Analysis -> control card. when I go to control cards there are only options to choose to what to run.
I would appreciate if you could lead me to these options since I am not able to see any result from my run as well.
