Hi! I recently started using hypermesh and Optistruct and I cama across error #802 as shown below:
*** ERROR # 802 ***
Repeated factorization failure due to panel limitations on pivoting.
Solver error no. = -513
subcase id = 1
default panel size = 256
increased panel size = 4096
Please increase panel size by PARAM,PNLSIZ and rerun the problem.
I'm using hypermesh 2017.3 and I can't seem to find 'PARAM,PNLSIZ' anywhere... How can i solve this problem? Also, what can cause this issue, as for me the error description is not sufficient to understand what might be causing the problem...
Thank you in advance!
