Tyre Assembly Analysis
Hi Johnson,
Kindly find the image sent to you in drop box
Wheel with tyre assembly is given load at center by using rigid element
Ground defined as shown in the image. Contact defined between tyre & Ground
How this type of analysis can be done in optistruct<?xml version="1.0" encoding="UTF-8"?>
Any update on the above query?
0 -
Hi Naveen,
One of the local AE's from INDIA will get in touch with you soon.
0 -
Hi Naveen,
What is the objective of the simulation, based on which methodology can be decided.
Based on above inputs, the force as function of time can be applied at tyre centre and transient run can be performed.
0 -
Hi Mr.Gopal,
Thank you for the reply
Can be done in transient. We are planning to do in optistruct.
Steel property defined for wheel. Rubber property to be defined for tire
What material card can be defined for rubber property in optistruct (Suggest us in material card and basic properties)
Load is given using rigid element at disc centre
Contact between ground and tyre defined(need clarification on defining contacts)
Image attached for your reference
0 -
Hi, Any clarification on this query?
0 -
Hi Naveen,
You can run a non linear transient analysis and for rubber material please refer MATHE card on OptiStruct help.
But in case you want to include monitored volume, it is better if you use RADIOSS.
0 -
Pneumatic structures can be modeled in Optistruct by applying outward facing pressure load.
0 -
Hi naveen, i'm trying to model similar problem in optistruct for my study, and i have some queries to ask.
how could i contact u regarding this?
