Hi! I am new here and I also new with the program, I what to ask if someone can help me with this because allways that I try to make an Topology optimization I have the same ERROR and is this one is it:
Created RAM scratch area: total size 200.00 MB
*** ERROR # 1000 in the input data:
Incorrect data in field # 3.
Detected while reading line 4406 from file
C:/Temp/baraja/va a funcionar/solid mit mesh funcionara.fem:
'CTETRA 21985 0 5178 5177 5111 7486'
This line was interpreted as:
4406:CTETRA, 21985, 0, 5178, 5177, 5111, 7486
Expected INT > 0, found INTEGER (0).
Syntax error(s) found in bulk data 'CTETRA' card.
Detected while reading line 4407 from file
'CTETRA 21986 0 3455 5999 3454 6010'
4407:CTETRA, 21986, 0, 3455, 5999, 3454, 6010
Detected while reading line 4408 from file
'CTETRA 21987 0 3455 3454 4449 6010'
4408:CTETRA, 21987, 0, 3455, 3454, 4449, 6010
and continous...
Thank you for the helps!
