Can we manually enter Shear Center (Zg) value in S-Frame for a Beam
Hi Harshal,
Thank you for getting in touch. I'm afraid S-FRAME does not have an input for shear center of a beam. S-FRAME assumes the shear center coincides with the section centroid for analysis purposes.
With that said, Scratch Pad (accessible through S-STEEL's Run Menu) does allow users to specify Zg for their beam when using the EuroCode.
Hopefully this clears things up.
Regards,Matthew Sauer
Altair Support
