I want to gnenerate volume tetrahedron mesh based on surface meshes. Let's say I creat a cube and a surface inside the cube, I first mesh the surface with tri mesh and then I want to mesh the whole volme base on the surface mesh I just create. Is there a way to do that in hypermesh. I tried to use 3D tetra volume mesh but it seems not wokring. Can someone give me some hints?
