I used RBE2 for creating spiders in my problem. However it stiffens the cross-section of the part. Is there any option to created deformable spiders or multi-point constraints?
I mean option similar to spiders in which all three Dofs of independent node should be transferred to all dependent nodes with any weight factor. I need option similar to distributing couplings in optistruct. Is the optistruct MPCs are similar to the option I require?
Will you give some guidelines on this? How to create this in optistruct?
