Hi guys,
I want to realize the pipe (you can see it in the data, picture1) as a composite part made out of CFRP.
I want to do it like the exercise with the skateboard.
it's an solid and already meshed. I checked the element normal. (2D -> composite -> element normals -> select elemtens -> all. (picture2)
I think that looks good!
But now, when I check the element orientation (under the submenu 'material orientation') then I get a chaos. The directions goes into any direction . (picture 3)
How do I get the orientations into the right direction?
And what are the next steps to do?
Due to be a newcomer, it would be fabulous if you can give me an instruction of what I have to do, step by step.
(I think I have to get the directions like you can see it in picture4. And the direction for the next layer, i have to fix it tangential to the radius, picture 5)
Thanks
