In a topology optimization I get the following message
ERROR # 312 FROM SUBROUTINE clcuku
In static load case 1 the compliance is negative or large -1.976274E+06
Optimization/buckling analysis cannot be performed due to possible rigid body mode
I've verified all elements/nodes are attached, it's a running nastran model. I have 4 components to be optimized. This is the first time I've run multiple design spaces in 1 analysis. Each design space is independant of each other but but attached to the surrounding structure.
