I created an assembly on CATIA and imported it onto Hypermesh. When I try to mesh the parts, no matter how many parts I select i get 0 parts selected for emshing-No change... What might be the issue... I need help...
i think its an error while exporting from catia, ensure that you are exporting the prototype bodies and not an occurence/component of those parts in the assembly.
-- cae.developer@gmail.com
thanx for the reply... but since i am a beginner can u tel me wat 'prototype bodies mean'.. thanx again for the timely help...
I believe the previous answer mentioned that since you have an assembly you must import inside hypermesh the constituent parts of it and not subparts of the assembly. Anyway, a rather cumbersome way to do what you want is to import the parts of your assembly one-by-one instead of the whole assembly in one import. Try to import the CATIA geomerty (as .catpart, or .stp or .iges) of one part of the assembly in HM, mesh it and save it as .hm file. Repeat the process for all parts. Then open one of the meshed parts and import the rest by selecting import-->import HM model.
thats a very good solution from mvass, kumar try that
thanx mates....hope that works..... wil let u guys know if i have further problems....
Save your CAD model with .igs file extension. Now import your CAd model into Hypermesh by checking in import portal that, Import Geometry and File Extension is iges.
