Boolean operations. Creating general surfaces
Hello all. I have a question. Is it possible to create with .tcl commands general surfaces, but for all solids.
It is very tedious to constantly perform repeated commands. And script could solve this problem.
For example this detail:
This surfaces were made by next commands:
add_button 'Make boolean surfaces' { *createmark solids 1 1 *createmark solids 2 5 *boolean_merge_solids 1 2 14 2 *createmark solids 1 1 *createmark solids 2 5 *boolean_merge_solids 1 2 14 2 *createmark solids 1 2 *createmark solids 2 1 *boolean_merge_solids 1 2 14 2 *createmark solids 1 3 *createmark solids 2 1 *boolean_merge_solids 1 2 14 2 *createmark solids 1 4 *createmark solids 2 1 *boolean_merge_solids 1 2 14 2 *createmark solids 1 5 *createmark solids 2 1 *boolean_merge_solids 1 2 14 2 *createmark solids 1 2 *createmark solids 2 2 *boolean_merge_solids 1 2 14 2 *createmark solids 1 2 *createmark solids 2 3 *boolean_merge_solids 1 2 14 2 *createmark solids 1 2 *createmark solids 2 4 *boolean_merge_solids 1 2 14 2 *createmark solids 1 2 *createmark solids 2 5 *boolean_merge_solids 1 2 14 2 *createmark solids 1 3 *createmark solids 2 1 *boolean_merge_solids 1 2 14 2 *createmark solids 1 3 *createmark solids 2 2 *boolean_merge_solids 1 2 14 2}
But if we have about 100+ solids and more?
How to solve this question\problem?
Thanks!
Hi
Try simple loops like this.
for {set i 1} {$i<6} {incr i} {
for {set j [expr $i+1]} {$j<6} {incr j} {
*createmark solids 1 $i
*createmark solids 2 $j
}0 -
Altair Forum User said:
Hi
}Thank you. It works /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
