Hey all,
firstly i am new in this Forum an i like working with Hyperworks. But sometimes it is a little bit difficult.
I have a 3 point bending test and want to hold the ends of the tube firmly. So I prepared the model in hypermesh and then changed to hyperform. The boundary conditions are displayed in the container load collector. As soon as I execute the process, they are deleted again. What can I do? The modell is a shell.
Thank you!
U should apply BCs in Hyperform itself. However, if u r using default process from toolbar & before that u applied BCs all previous BCs will deleted & new BC according to selected process will generate. For that u have to go for manual process. plz share model or screen shot that will give more clear idea of your problem.
