When use optistruct to analysis mode, error 15 occured.
The out file display Resource useage information:
Current memeroy 1646Mb
Estimated min memeroy for check run 1680Mb
So there is a fatal error.
But the system ram is 16GB., not other program running. I try -len -fixlen parameter, it doesn't work. This model have about 800 000 nodes. The oprating system is XP 64bit, HW64.
I used the same model on several other computers, the same error occurs.
Why there is only 1646Mb , however the system ramain 16GB & hw64 can support this ram.
