ERROR # 772
Hi All,
I am trying to run an analysis on a pipe section subjected to torsion.
When I run the analysis I get the below message
***There were 4 error messages during input processing***
Hi Luke,
The error would generally be because of RBE3 nodes that are not connected to any part of the structure, this would create singularity in the model and hence OptiStruct throws the error message. you can repair this manually or
We have an automatic way to fix this starting from 13.0 using a Param card, PARAM,RBE3FREE,YES.
12.0 - you can add the below debug card to overcome this issue ( Analysis > Control Card > DEBUG) with version 12.0 or before
DEBUG,RBE3ERR,1
0 -
I too am getting the same error but I cannot find the option RBE3FREE in the PARAM card. Can you please help?
Thanks,
Suraj.R
0 -
Suraj,
Independent node on RBE3 should not be free. It should be connected to another element.
Try to figure out this or you can use RBE2 instead.
In version 14, go to Control cards>> PARAM>>RBE3FREE>> YES
0 -
