Nearest nodes
Altair Forum User
Altair Forum User
how to find nearest node in hypermesh. A command or any macro that should search a tolerance of distance like within radius of 30  and then find nodes within that perimeter . lets say, should find nodes adjacent to it.
  • tinh
    tinh Altair Community Member
    edited May 2017
    Hi
    You can select nodes within a sphere
    *createmark nodes 1 'by sphere'
    -> i dont remember args so please look up reference help. ;)/emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20' />
  • Altair Forum User
    Altair Forum User
    edited May 2017
    Hi Sonu,
    The API is  *createmark nodes 1 'by sphere' x y z r inside 1 1 .1
  • Altair Forum User
    Altair Forum User
    edited May 2017
    hi johnson and tinh
    thank you for the answer. was really grateful.
    However, I need a little more favour pls.
    As you suggested i was able to create a sphere with a central node. however, i want to add those nodes in the form of temporary nodes because as soon as i turn of elements, the nodes dissapear too.
    once i have added the nodes, i want to automate it for n number of nodes. how can i run the process in a loop through a tcl.
  • Altair Forum User
    Altair Forum User
    edited May 2017
    Hi Sonu,
    Once the nodes are displayed using *createmark nodes 1 'by sphere' x y z r inside 1 1 .1 option, you can go to Shift + F2 option and directly add those nodes, so that those nodes will be displayed.
  • Altair Forum User
    Altair Forum User
    edited May 2017
    hi johnson, but the problem is, as soon as i turn off the elements, the nodes dissaper too with elements.
  • tinh
    edited May 2017
    Hi
    I am not sure what you want to do with the nodes
    to mark them as temporary
    set NodeList [hm_getmark nodes 1]
    *nodemarkaddtempmark 1
    foreach NodeId $NodeList {
         # do you job with each node here
  • Altair Forum User
    Altair Forum User
    edited July 2018
    Is there any code to select the nodes where two components are intersecting? I tried using hm_getnodessharedbyothercomps but the nodes are not selecting.
    Thank you in advance for any reply
  • tinh
    edited July 2018
    Maybe you have to use command *penetrationcheck
