Is there a way to reverse the orientation of axes in HyperGraph?
Simply, I want the negative portion of the horizontal axis to start at the origin and point right rather than left.
Unfortunately, this is not directly supported as of HW 9.0. However, to visually see the curve running along the axis in the reverse direction:
1. Enter the Scales and Offsets panel from the Curve menu or by clicking on the panel icon on the toolbar
2. Set the axis Scale: field to -1
3. Click Apply
This will orient the curve so it is running in the opposite direction
I need the axis to run in the reverse direction as well.
When plotting in Excel, there is an axis option called Values in reverse order. This would be a useful feature for HyperGraph.
