Dear all,
Can anyone tell me what happens when I don't check the 'Use corner data'? Why the results are so different.
I'm evaluating a beam with a bending load and comparing the results with the analytical solution, using corner data on, with simple averaging the results match the analytical solution exactly! With 'Use corner data' off, the results diverge a bit...
I'm using solid elements (C3D8I from Abaqus).
If someone has done a study about this, please tell me your experience.
Thanks a lot...
