error#41
Altair Forum User
Altair Forum User
*** ERROR #   41 ***
CBAR            #      2783 has an invalid orientation vector.
 *** ERROR #   41 ***
CBAR            #      2784 has an invalid orientation vector.
 *** ERROR #   41 ***
CBAR            #      2785 has an invalid orientation vector.
 *** ERROR #   41 ***
CBAR            #      2786 has an invalid orientation vector.
 *** ERROR #   41 ***
CBAR            #      2787 has an invalid orientation vector.
 *** ERROR #   41 ***
CBAR            #      2788 has an invalid orientation vector.
 *** ERROR #   41 ***
CBAR            #      2789 has an invalid orientation vector.
 *** ERROR #   41 ***
CBAR            #      2790 has an invalid orientation vector.
 *** ERROR #   41 ***
CBAR            #      2791 has an invalid orientation vector.
 *** ERROR #   41 ***
CBAR            #      2792 has an invalid orientation vector.
 *** More of ERROR messages # 41 were suppressed...
Dose someone know how to solve this prolem ? Thank you!!
  • Altair Forum User
    Altair Forum User
    edited August 2014
    Please check the orientation of the bar element and change the orientation accordingly.
    A quick suggestion: before you run the analysis when using bar and beam elements, change the element representation to 3D and check if they are properly oriented or not. image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
  • Altair Forum User
    Altair Forum User
    edited August 2014
    Thank you! But wen I check the elements ,they are all properly oriented.
  • Altair Forum User
    Altair Forum User
    edited August 2014
    can you check if there any free 1D elements or duplicate 1D elements in your model?
    go to >> tool>> check elems>> 1D>> free 1d's
    if there are any free 1D elements, please connect them. Delete any duplicate 1D elements.
    if there are no free 1Ds, change the orientation of the CBAR elements and run the job.
  • Altair Forum User
    Altair Forum User
    edited August 2014
    There are no free 1Ds or duplicate 1Ds.But there are so many elements calculated orientation error,I should change the orientation of them all one by one ,should I?And when I change the orientation of them ,they are not same with the orientation of the original geometry.
  • Altair Forum User
    Altair Forum User
    edited August 2014
    can you share the model file?
    Please use the Dropbox in the signature below to share the file.
  • Altair Forum User
    Altair Forum User
    edited August 2014
    It's the first time I use the HyperMesh to simulat ,so it maybe very coarse.Please do not hesitate to correct me when I make mistakes.Thanks.
  • Altair Forum User
    Altair Forum User
    edited August 2014
    Sorry,the internet speed is too slow to send the model.I will send it to you tomorrow ,OK?
  • Altair Forum User
    Altair Forum User
    edited August 2014
    okay no problem image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
  • tinh
    tinh Altair Community Member
    edited August 2014
    You can change orient vector by 1D>bar>update
    select same section elements and update once
    change visualization to '3D Representation' to see if the bars are not same direction with actual geometry
  • Altair Forum User
    Altair Forum User
    edited August 2014
  • Altair Forum User
    Altair Forum User
    edited August 2014
    Sorry ,I have upload the model several times but everytimes it had failed .Can you give me your Email,I send it to you?
  • Altair Forum User
    Altair Forum User
    edited August 2014
    Thanks.I kown this command just because there are so many errors to solve.When I solve one ,it will come a new one about it.So I want to find a convinient way to solve it.
  • tinh
    edited August 2014
    Yes, but in your case, many errors is 1 error
    just update them all once
  • Altair Forum User
    Altair Forum User
    edited August 2014
    I sent you the modified model.
    Please let us know if you are able to run the model.
  • Altair Forum User
    Altair Forum User
    edited August 2014
    Sorry,my version is 11.0,I can't open the modifide model.
  • Altair Forum User
    Altair Forum User
    edited August 2014
    But it didn't display once,when I modified the model and optistruct it again it will appear more.
  • Altair Forum User
    Altair Forum User
    edited November 2020
    i face same problem that invalid orientation. i attached .hm file here
    please any one have answer please help me.
    i use 13.0 version of hypermash
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited April 2016
    Give proper orientation and create bar element.See attached screenshot.
    Regards
    Rahul R
  • Altair Forum User
    Altair Forum User
    thanks for responding me sir
    later on i done size optimization by using solid section but error is generate
    INFEASIBLE DESIGN (AT LEAST ONE CONSTRAINT VIOLATED
  • Altair Forum User
    Altair Forum User
    edited April 2016
    Hi Ishwar,
    Can you reduce the force and try again (say 1000 on each node)?
  • Altair Forum User
    Altair Forum User
    edited April 2016
    ok.. i do
  • Altair Forum User
    Altair Forum User
    edited April 2016
    i got same result when reduce force 1000
  • Altair Forum User
    Altair Forum User
  • Altair Forum User
    Altair Forum User
    edited April 2016
    hii.. prakash
     it fail to generate .fem file please send .hm and .jpg file
  • Altair Forum User
    Altair Forum User
