Altair RISE
Nominate Yourself Now!
Created Vector and Retrieving Coordinates of it.
User: "Altair Forum User"
Updated by Altair Forum User
hello everyone,
I had created the vector from
Analysis -> Vector
now i want to get/retrieve the coordinates of this particular vector to use these coordinates in
*createvector 1 $ox $oy $oz
i had tried the hm_getentityvalue to retrieve the coordinates of the vector as we do for nodes
set ZVx [hm_getentityvalue vectors $Zvector 'globalx' 0]
even not able to find the ID of the vector.
please help me in resolving this issue.
thanks
Adams
1 - 8 of 81
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hello
    There are 2 kinds of vector and your mention is about vector entity. to create it using *vectorcreate
    and refer to data names of vector entity you can find its component (to use with hm_getentityvalue)
    OP
    Hi tinh,
    Thanks for replying image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    i am trying to retrieve the coordinates through 'vector' as an entity.
    firstly i had created the vector as an entity through
    *vectordrawoptions 15 0 1
    *vectorcreate_twonode $Node1 $Node2
    saved the vector in one variable :
    set Zvector [hm_getmark vectors [*createmark vectors 1 -1]]
    then trying to retrieve the coordinates through :
    set X [hm_getentityvalue vectors $Zvector 'globalx' 0]
    Y...
    Z...
    and want to put in :
    *createvector 1 $X $Y $Z
    but here value of X, Y, Z is not retrieved.
    thanks
    Shivanshu
    User: "tinh"
    Updated by tinh
    Hello Shivanshu
    did you read all data names of vector entity?
    please confirm  is it exactly 'globalx' ? this is available for node entity but sometimes it differs from other entities
    OP
    Shivanshu,
    For vectors, you should use xcomp, ycomp and zcomp.
    http://www.altairhyperworks.com/hwhelp/Altair/hw12.0/help/hwdref/data_names_vectors.htm
    OP
    hi cesar & tinh,
    i had tried to retrieved the coordinates of vector with:
    set a [hm_getmark vectors [*createmarkpanel vectors 1 -1]]
    then for 'X, Y, Z - Coordinate'
    set VX [hm_getentityvalue vectors $a 'xcomp' 0]
    set VY [hm_getentityvalue vectors $a 'ycomp' 0]
    set VZ [hm_getentityvalue vectors $a 'zcomp' 0]
    but its not working.
    BASICALLY I WANT TO RETRIEVE THE COORDINATED TO DEFINE THE DIRECTION FROM THIS VECTOR.
    OP
    Import the following dyna deck into hypermesh using the Dyna profile
    $$ HM_OUTPUT_DECK created 06:12:32 03-19-2014 by HyperMesh Version 11.0.0.134
    $$ Ls-dyna Input Deck Generated by HyperMesh Version  : 11.0.0.134-HWDesktop
    $$ Generated using HyperMesh-Ls-dyna 971 Template Version : HW11.0.134-HWDesktop
    *KEYWORD
    *NODE
           1            10.0             5.0             2.5
           2            15.0            10.0             0.5
           5 14.531538935183             5.0 4.6130913087035
    *DEFINE_SD_ORIENTATION
    $HMNAME VECTORCOL       1auto1
    $HWCOLOR VECTORCOL       1      11
             1                 1.0       0.0       0.0
             2          4.53153894       0.02.11309131
             3                 5.0       5.0      -2.0
    *END
    After the import has been completed, copy the following tcl code into a file in your desktop, name the file get.vectors.tcl
     *createmarkpanel vectors 1 'Select vectors';set vectorList [ hm_getmark vectors 1 ];foreach a $vectorList {	set VX [ hm_getentityvalue vectors $a 'xcomp' 0 ];	set VY [ hm_getentityvalue vectors $a 'ycomp' 0 ]; 	set VZ [ hm_getentityvalue vectors $a 'zcomp' 0 ];  puts '$VX $VY $VZ';}
    In the command window type, source path/to/the/file/get.vectors.tcl and review the output.
    User: "tinh"
    Updated by tinh
    hi cesar & tinh,
    Hello
    to specify a direction from 2 nodes (or 3 nodes) you can retrieve node coordinates x, y, z and compute vector components by using hwat (or write it yourself)
    This is an example
    package require hwat
    *createlistpanel nodes 1 'Select direction by node1->node2'
    set nodelist [hm_getlist nodes 1]
    set nodeid1 [lindex $nodelist 0]
    set nodeid2 [lindex $nodelist 1]
    set coord1 [expr [hm_nodevalue $nodeid1]]
    set coord2 [expr [hm_nodevalue $nodeid2]]
    set vectorcomps [::hwat::math::GetVector $coord1 $coord2];#or you take x,y,z in coord2 plus x,y,z in coord1
    puts $vectorcomps
    you don't need to make vector entity
    OP
    thanks tinh & cesar.
