Created Vector and Retrieving Coordinates of it.
hello everyone,
I had created the vector from
Analysis -> Vector
now i want to get/retrieve the coordinates of this particular vector to use these coordinates in
*createvector 1 $ox $oy $oz
i had tried the hm_getentityvalue to retrieve the coordinates of the vector as we do for nodes
set ZVx [hm_getentityvalue vectors $Zvector 'globalx' 0]
even not able to find the ID of the vector.
please help me in resolving this issue.
thanks
Adams
Hi tinh,
Thanks for replying /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
i am trying to retrieve the coordinates through 'vector' as an entity.
firstly i had created the vector as an entity through
Shivanshu,
For vectors, you should use xcomp, ycomp and zcomp.
http://www.altairhyperworks.com/hwhelp/Altair/hw12.0/help/hwdref/data_names_vectors.htm
hi cesar & tinh,
i had tried to retrieved the coordinates of vector with:
set a [hm_getmark vectors [*createmarkpanel vectors 1 -1]]
then for 'X, Y, Z - Coordinate'
set VX [hm_getentityvalue vectors $a 'xcomp' 0]
set VY [hm_getentityvalue vectors $a 'ycomp' 0]
set VZ [hm_getentityvalue vectors $a 'zcomp' 0]
but its not working.
BASICALLY I WANT TO RETRIEVE THE COORDINATED TO DEFINE THE DIRECTION FROM THIS VECTOR.
Import the following dyna deck into hypermesh using the Dyna profile
$$ HM_OUTPUT_DECK created 06:12:32 03-19-2014 by HyperMesh Version 11.0.0.134
$$ Ls-dyna Input Deck Generated by HyperMesh Version : 11.0.0.134-HWDesktop
$$ Generated using HyperMesh-Ls-dyna 971 Template Version : HW11.0.134-HWDesktop
*KEYWORD
*NODE
1 10.0 5.0 2.5
2 15.0 10.0 0.5
5 14.531538935183 5.0 4.6130913087035
*DEFINE_SD_ORIENTATION
$HMNAME VECTORCOL 1auto1
$HWCOLOR VECTORCOL 1 11
1 1.0 0.0 0.0
2 4.53153894 0.02.11309131
3 5.0 5.0 -2.0
*END
After the import has been completed, copy the following tcl code into a file in your desktop, name the file get.vectors.tcl
*createmarkpanel vectors 1 'Select vectors';set vectorList [ hm_getmark vectors 1 ];foreach a $vectorList { set VX [ hm_getentityvalue vectors $a 'xcomp' 0 ]; set VY [ hm_getentityvalue vectors $a 'ycomp' 0 ]; set VZ [ hm_getentityvalue vectors $a 'zcomp' 0 ]; puts '$VX $VY $VZ';}
In the command window type, source path/to/the/file/get.vectors.tcl and review the output.
hi cesar & tinh,
Hello
to specify a direction from 2 nodes (or 3 nodes) you can retrieve node coordinates x, y, z and compute vector components by using hwat (or write it yourself)
This is an example
package require hwat
*createlistpanel nodes 1 'Select direction by node1->node2'
set nodelist [hm_getlist nodes 1]
set nodeid1 [lindex $nodelist 0]
set nodeid2 [lindex $nodelist 1]
set coord1 [expr [hm_nodevalue $nodeid1]]
set coord2 [expr [hm_nodevalue $nodeid2]]
set vectorcomps [::hwat::math::GetVector $coord1 $coord2];#or you take x,y,z in coord2 plus x,y,z in coord1
puts $vectorcomps
you don't need to make vector entity
Hello
There are 2 kinds of vector and your mention is about vector entity. to create it using *vectorcreate
and refer to data names of vector entity you can find its component (to use with hm_getentityvalue)
