I have a double supported beam that I have divided into a non-design and design space. After running an optimization and generating the structure with ossremesh I did an FEA reanalysis on the model. When checking the stress contours I noticed that their were discontinuities between the design and non-design space. Running edge and face equivalence showed that there were no unconnected nodes. Both the design space and non-design space have the same material, but located in different properties.
What could be the problem?
Thank you,
-Eric
