hello
what is the differences between optiStrict and RADIOSS
thanks
Altair® OptiStruct® is an industry proven, modern structural analysis solver for linear and non-linear structural problems under static and dynamic loadings. It is the market-leading solution for structural design and optimization. Based on finite element and multi-body dynamics technology, and through advanced analysis and optimization algorithms, OptiStruct helps designers and engineers rapidly develop innovative, lightweight and structurally efficient designs. OptiStruct is used by thousands of companies worldwide to analyze and Optimize structures for their strength, durability and NVH (noise, vibration and harshness) characteristics.Finite element solutions via OptiStruct include:• Linear static analysis• Non-linear implicit quasi-static analysis• Linear buckling analysis• Normal modes analysis• Complex eigenvalue analysis• Frequency response analysis• Random response analysis• Linear transient response analysis• Geometric non-linear explicit and implicit analysis• Linear fluid-structure coupled (acoustic) analysis• Linear steady-state heat transfer analysis• Coupled thermo-mechanical analysis• Inertia relief analysis with static, non-linear contact, modal frequency response, and modal transient response analyses• Component Mode Synthesis (CMS) for the generation of flexible bodies for multi-body dynamics analysis• Reduced matrix generation• One-step (inverse) sheet metal stamping analysis• Fatigue analysisA typical set of finite elements including shell, solid, bar, scalar, and rigid elements as well as loads and materials are available for modeling complex events.Multi-body dynamics solutions integrated via OptiStruct for rigid and flexible bodies include:• Kinematics analysis• Dynamics analysis• Static and quasi-static analysis• LinearizationAll typical types of constraints like joints, gears, couplers, user-defined constraints, and high-pair joints can be defined. High pair joints include point-to-curve, point-to-surface, curve-to-curve, curve-to-surface, and surface-to-surface constraints. They can connect rigid bodies, flexible bodies, or rigid and flexible bodies. For this multi-body dynamics solution, the power of Altair MotionSolve has been integrated with OptiStruct.Structural Design and OptimizationStructural design tools include topology, topography, and free-size optimization. Sizing, shape and free-shape optimization are available for structural optimization.In the formulation of design and optimization problems, the following responses can be applied as the objective or as constraints: compliance, frequency, volume, mass, moment of inertia, center of gravity, displacement, velocity, acceleration, buckling factor, stress, strain, composite failure, force, synthetic response, and external (user-defined) functions. Static, inertia relief, nonlinear quasi-static (contact), normal modes, buckling, and frequency response solutions can be included in a multi-disciplinary optimization setup.Topology, topography, size, and shape optimization can be combined in a general problem formulation.Topology OptimizationTopology optimization generates an optimized material distribution for a set of loads and constraints within a given design space. The design space can be defined using shell or solid elements, or both. The classical topology optimization set up solving the minimum compliance problem, as well as the dual formulation with multiple constraints are available. Constraints on von Mises stress and buckling factor are available with limitations. Manufacturing constraints can be imposed using a minimum member size constraint, draw direction constraints, extrusion constraints, symmetry planes, pattern grouping, and pattern repetition. A conceptual design can be imported in a CAD system using an iso-surface generated with OSSmooth, which is part of the OptiStruct package.Free-size optimization is available for shell design spaces. The shell thickness or composite ply-thickness of each element is the design variable.Topography OptimizationTopography optimization generates an optimized distribution of shape based reinforcements such as stamped beads in shell structures. The problem set up is simply done by defining the design region, the maximum bead depth and the draw angle. OptiStruct automatically provides the design variable creation and optimization control. Manufacturing constraints can be imposed using symmetry planes, pattern grouping, and pattern repetition.Size and Shape OptimizationGeneral size and shape optimization problems can be solved. Variables can be assigned to perturbation vectors, which control the shape of the model. Variables can also be assigned to properties, which control the thickness, area, moments of inertia, stiffness, and non-structural mass of elements in the model. All of the variables supported by OptiStruct can be assigned using HyperMesh. Shape perturbation vectors can be created using HyperMorph.The reduction of local stress can be accomplished easily using free-shape optimization. Shape perturbations are automatically determined by OptiStruct (based on the stress levels in the design) when using this technique.The layout of laminated shells can be improved by modifying the ply thickness and ply angle of these materials.Multi-body Dynamics AnalysisDifferent solution sequences for the analysis of mechanical systems are available; these include Kinematics, Dynamics, Static, and Quasi-static solutions.Flexible bodies can be derived from any finite element model defined in OptiStruct.
Altair® RADIOSS® is a leading structural analysis solver for highly non-linear problems under dynamic loadings. It is highly differentiated for Scalability, Quality and Robustness, and consists of features for multi-physics simulation and advanced materials such as composites. RADIOSS is used across all industries worldwide to improve the crashworthiness, safety, and manufacturability of structural designs. For over 20 years, RADIOSS has established itself as a leader and an industry standard for automotive crash and impact analysis.Finite element solutions via Altair RADIOSS include:• Explicit dynamic analysis• Non-linear implicit static analysis• Transient heat transfer and thermo-mechanical coupling• Explicit Arbitrary Euler-Lagrangian (ALE) formulation• Explicit Computational Fluid Dynamics (CFD)• Smooth Particle Hydrodynamics (SPH)• Incremental sheet metal stamping analysis with mesh adaptivity• Linear static analysis• Normal modes analysis• Linear and non-linear buckling analysis
thank you alotthis will help me for my project
