Hy guys
I am performing an analysis of impact in RADIOSS and this error appears: ERROR IN INITIAL PENETRATION IN INTERFACE
The .out file is attached.
Somebody can help me?
Thanks
Hi felipeds
Check if there is any initial penetration in your model. Use Tool>> Penetration to check for penetrations and intersections.
If there is no penetrations or the penetrations is no resolved, you can change Iacti= 6 in TYPE 7 interface card. Please let us know if this helped.
Hi felipeds Check if there is any initial penetration in your model. Use Tool>> Penetration to check for penetrations and intersections. If there is no penetrations or the penetrations is no resolved, you can change Iacti= 6 in TYPE 7 interface card. Please let us know if this helped.
Hi Praksh
I have the same problem. When I use penetration tool to check it said that Unspecified thickness of my components. They are shell. I also use type 7 and Inacti = 6. Could you please tell me how to deal with this problem!
Ensure that properties created are assigned to the components and fix the penetrations in the model.
Hi, Ensure that properties created are assigned to the components and fix the penetrations in the model.
Thank you George
The properties created are assigned to the components, but I do not know how to fix the penetration in the model. Could you please suggest me some documents about that.
Thank you
Please go through this post which describes about collision detection tool:
Also, go through a tutorial on penetration fix from the Help Menu, HM-3320: Penetration which explains every step.
