When I start an analysis by using OptiStruct , the message that 'radflex10_wnt.exe encountered a problem and needs to close' message. How can I fix it?
Best Wishes
When I start an analysis by using OptiStruct , the message that 'radflex10_wnt.exe encountered a problem and needs to close' message. How can I fix it? Best Wishes
Which version of radflex do you use? (Right click on it and find the version tag)
Maybe if you apply hwsolvers update, it could be useful.
Good post. I appreciate it! Thanks for guiding.
