Is it possible to put equations in Optimisation Constraints?
I would like to use Eulers Equation in a Buckling Constraint in a model using CBARL to enable the area moment of Inertia to adjuct as the x-section changes
Any thoughts?
You can define a DRESP2 response by using dequation. Then the response can be used to define a constraint.
