Inspire python code strutLattice( trimmingBody= ) problem
Hi there,
I have a problem with trimmingBody parameter of inspire python method inspire.strutLattice(). While using the Impilicit Modeling -> Strut tool, I can trim my implicit part by selecting the trim part from the outerbody->shell->trimmingBody section. However when I use inspire.strutLattice() method with shell=True parameter, shell work but trim don't work.
Example:
implicitPart.strutLattice(body=implicitPart.bodies[0], unitCellType='CORNERDIAGONAL', strutDiameter=0.004, cellSizeX=4,shell=True ,trimmingBody=XXXXX ,shellThicknessOut=0.0005)
What should XXXXX be here? How can I make my trim part in my model work here?
I have same problem with parameter combineBody.
Example:
implicitPart.strutLattice(body=implicitPart.bodies[0], unitCellType='CORNERDIAGONAL', strutDiameter=0.004, cellSizeX=4,combine=True ,combineBody=XXXXX).
