In tutorial there is an example to generate superelemnent in linear static analysis.
But I need to do modal analysis using superelement. I hope very much if someone in this field can give me a step-by-step manual I can follow. Thanks!
Please find attached deck and doc for modal analysis using superelement.Please go through that and let us know your feedback.
Regards
Rahul R
NOTE FROM COMMUNITY TEAM: The zip file that was originally attached to this Question is no longer available. Please post a question in the Community for additional help.
Hi,Please find attached deck and doc for modal analysis using superelement.Please go through that and let us know your feedback.RegardsRahul R
Thank you very much for your referrence file. It's simlimar to the procedure using CMSMETH in Linear Static.
But when I imported cantilever_cms.fem and run optistruct in hw13.0(I've check the card but didn't change anything ), It failed and said Card 'METHOD(STRUCTURE)' is not allowed for this subcase type. What's wrong with it. I'm trying to solve the problem.
