Dear all
I post for the first time.
/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'> I'm Takky, Yokohama National University in Japan.
Could you please tell me how to output the load force of side members and the barrier surface in contact analysis? I need its graph.
I can't output the load force data of the barrier nor side member.
I once used the output block on each RBODY of the barrier surface and side member, but no data was output.
On HyperGraph, only 'Global Valuables' is available, but no other data in 'T01-file'.
In this analysis, the bumper model crash into the rigid offset barrier surface in front, in initial velocity of 50km/h(13.9mm/s).
The analysis sample on this image, I wanted to output the each load force of right and left member, but couldn't.
In another analysis, I made one rigid body from two members and tried as equal, but couldn't. So, it's not because there are two rigid bodies in rear of bumper, I think.
I sent its HM data together.
Any ideas??
