when using SAE filters you have to convert your data in the time history file to seconds. How do you do this? Is it as simple as > advanced options > curve options. under build plots?
Any help would be appreciated!
Many thanks
Please find attached tutorial which explains in detail the usage of SAE filter 60.
Could you upload the document again? Apparently the file cannot be downloaded.
