I've been running 3D Topology Optimizations and have been playing around with my Min/Max member size. However, I don't see much change in my results between numerical values for max and min member size, unless I turn the feature off (in which I get a handfull of disconnects). I took a Optistruct class and have read a few tutorials, but have yet to get a clear answer on what the value for max and min size is actually doing. Plus, when I decreased my mesh size, I get an warning saying my min size is too big.
Can someone please explain what exactly I am setting when I change this value - is it a relation of my mesh size or unit size? And if so, what should I set it at? I'm 3D printing so manufacturing limitations aren't significantly pertinent. However, If I don't set them I get obvious bad results.
Thanks
-Dave
