I am trying impact analysis in block 100 format i got the below error.help me to solve this error if possible guide me on this
ERROR id : 61** ERROR IN MATERIAL/ELEMENT DEFINITION (NUMBER)INVALID MATERIAL NUMBER 0FOR BRICK 203
Approximately you're using wrong material for your element. Maybe shell for solid elements...
But please look for your assingnment between material-component.
Thanks.
Thanks for your reply iondergumus.The mistake is i forget to give component card image(as part)
Yes I forgot this /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'> Thanks in advance...
Can you help me on this error
ERROR id : 668** INPUT ERRORNO NODE GROUP DEFINED IN /ADMAS OPTION ID=1216080
mee too hv same prob
Hi Pankaj,
looks like you have not assigned the mass on a node. please check this.
