Hallo everybody,
is it possible to create a composite Shell Element with variable layers? I had already found the '/PROP/TYPE11 - Sandwich Shell Property Set' but the problem is that this property only supports material law 25 and 27. I would like to build a shell with three layers, two of them definied by material law 25 and the third definied by an user material (law 29).
In the discription of prop/type11 is written that the property also supports user laws but this seems not to be true.
Can anyone help me?
fabian0989
