Hi all,
I have a a model composed by about 10 parts. The model was made into Catia. After importing the geometry into Hypermesh, I linked the parts in contact between boolean operations. Now the topology of the model is correct and I want to create a 3D mesh of all parts. The problem is that for some components I'm not able to create 3D mesh by tetra meshing because the elements contains free edges. I read somewhere that a way to fix this problem is to use edge panel in tools but unluckily It didn't work for me. Can someone help me suggesting the best way to procede?
I also tried to realize 2d mesh over the component surfaces and in this case there's a very strange problem. In fact automesh process works without issues or warning and I'm also able to visualize the preview of the mesh (green), but when I leave the automesh panel mesh is present only on some of the surfaces I selected (in particular, mesh is not applied to surfaces adjacent on free edges I visualized by edge panel).
Here's the model:
https://www.dropbox.com/s/3iaso5c0pkxqod8/2.hm?dl=0
The components that I'm unable to mesh are ID 2,4 and 20.
