GPFORCE/SPCForce
I request for the reaction force output to see it in the HV/HG result types menu. In Optistruct, I activate GPFORCE from GLOBAL_OUTPUT_REQUEST & also in loadstep activate Analysis,Output as a displacement,stress and GPFORCE option.Finally I ran the NLGEOM analysis and trying to see the results in hyperview,but i am unable to see the GPFORCE in result types menu.Please suggest the solution.
Please refer to the image below from Help about supported solution sequences for GPFORCE:
Please note: If you are a commercial customer, you can contact your local support for a quicker solution @ http://www.altairhyp...ortProduct.aspx
0 -
As per you suggested i use the OP2 format for NLGeom static analysis, i am able to see only the stress and displacement plot but unable to find exact force through GPFORCE command. Please suggest the solution in proper step.
0 -
Please sir suggest the solution.
0 -
Tushar,
GPFORCE is not supported for NLGEOM,
Instead you can run NLSTAT.
0 -
hi Prakash,
could you tell me an option for Geom non-linear analysis where i should get a GPFORCE-Displacement diagram? with Nonlinear quasi static i can not solve because of contact.
Thanks in advance!
0 -
GPFORCE output is available for the following solution sequences:
Solution Sequence
Static Analysis
H3D, OP2, PCH, OPT
Normal Modes Analysis
H3D, OP2, PCH
Direct Frequency Response Analysis
H3D, OP2, PCH, OPT
Modal Frequency Response Analysis
H3D, OP2, PCH, OPT
0 -
You can run the NLGEOM analysis which will write out .rad files. Use these files in RADIOSS to request reaction forces using output blocks.
