Hello...,
Currently, I have an ERROR # 192 when running a large file in Radioss (~500mb *.fem).
My system is workstation Intel® Xeon® CPU W3680 @3.33 GHz
Ram: 12 GB
64Bit OS
The details as follows:
NONLINEAR ITERATION SUMMARY FOR Subcase 1
LOAD STEP: 0.1000
Nonlinear Error Measures Gap/Contact Status
ITER EUI EPI EWI Open Closed
1 9.9000E+01 7.5286E-05 7.5286E-05 222 44
2 3.0544E-02 6.9100E-06 4.3588E-06 231 35
3 1.9160E-03 1.1238E-07 1.2106E-08 235 31
4 1.4125E-04 0.0000E+00 0.0000E+00 235 31
LOAD STEP: 0.2000
1 4.9675E+01 8.3937E+03 4.1805E+03 164 102
*** ERROR # 192 ***
Possible programming Error :
Unexpected error condition from subroutine 'xdslvf'
ioerr(1) = -404
ioerr(2) = 1
***** PROGRAMMING ERROR *****
***** INTERNAL PROGRAMMING ERROR *****
in file 'nlstatslv.F', at location # 1033
ioerr(1) = 0
ioerr(2) = 0
ioerr(3) = 577
**** ABORTING RUN DUE TO AN INTERNAL ERROR ****
RADIOSS/OptiStruct error termination report:
RAM: 8046 MB total, 1 MB used.
Data arrays: 235 total, 176 allocated.
DATA SET size 0 MB, ram_disk 2 MB
DATASET USAGE: ndirs: 1, nfiles 1, nsets: 7, nblocks: 8, mode: 8
DIR: 0, size 3987[MB], path 'D:/Congviec/21-08/' num_files 1
OptiStruct traceback info at: 08/21/11 19:55:17
Trace point: 10:694
( 0) 10 optist.F:694
( -1) 20 prpdrv.F:9146
( -2) 10 optist.F:449
( -3) 14 flim.F:204
( -4) 10 optist.F:429
( -5) 21 prp1drv.F:1657
( -6) 10 optist.F:416
( -7) 29 prp0drv.F:725
( -8) 10 optist.F:395
( -9) 11 readnew.F:6485
(-10) 16 reorder.F:467
(-11) 11 readnew.F:3505
(-12) 10 optist.F:113
Internal Trace
( 20) prpdrv.F:9146
CPU times[sec]: user 27148.697, system 565.270, Wall clock 27713.967
Command line arguments:
\Congviec\21-08\mam_xoay_Final.fem
-nproc=6
-exec=RD
File stats with output file root: mam_xoay_Final
Work directory: './' Free size 86.1 GB
243333192 mam_xoay_Final.3988_00st.scr
22856 mam_xoay_Final.3988_scr.s40
57137288 mam_xoay_Final.3988_scr.s44
0 mam_xoay_Final.3988_scr.w41
0 mam_xoay_Final.3988_scr.w42
Work directory: 'D:/Congviec/21-08/' Free size 31.7 GB
473935231 mam_xoay_Final.fem
109400747 mam_xoay_Final.hm
10119 mam_xoay_Final.out
1959 mam_xoay_Final.stat
4093791024 mam_xoay_Final_3988_00.scr
Anybody can tell me what the error is and how to fix this problem.
Thanks you very much
