Hi, everyone, I'm new in using altair's product. I used hypercrash to set up a gear pair, then used radioss to cal the contact forces, but some errors pop out.listed below.
** ERROR IN INPUT DATA
REFERENCE DIRECTION IS ALMOST NORMAL
TO SHELL 70411, PROPERTY SET 1
** ERROR IN PROPERTY/ELEMENT DEFINITION (TYPE)
INVALID PROPERTY TYPE 14,
FOR SHELL 77734
There are 4416 ERROR(S) messages like above, how to fix that, I think there must be something wrong with the property settings, but I don't know how to fix it. thanks for advanced!
It turns out that I forget to delete 2D element in the model, assigning the wrong property to it ,problem solved!
