I have transfered an excel file into a csv format. After importing to the hypergraph, I got an error message telling me 'unable to recognize the file'. Please see the attachment for reference.
I got this error but it appears to be in a different way. I was opening a .txt file in excel on a Mac and when I went to save as a csv and open in hypergraph, it didn't work. I had to select save as a 'Windows comma separated file' and that solved my problem. Maybe from excel there are a few different ways to save as a csv and you could try a few?
One of my IT guys explained it to me and it was something along the lines of creating it in a unix environment when it should have been a carriage return format.. (or something close to this)
May be you should try again with define curves button instead of build plots buttons
you need to export the csv from excel to a specific (sub-)format. I had trouble myself with it, but since i keep to the following rules, the import to HG works:
When exporting csv from Excel always
