Is there a way of converting a shape made of a lathed surface into a solid? (see attached picture/file)
Also, can I make an indent in my surface that would fill the area marked by the yellow curve?
THX
Either youre lathe allready acts like a solid or you could run the 'make manifold'.
And what do you mean with 'indent'?
- just an offset recess like a negative overmold or more like
an independent shape ?
Did you have something like this in mind ?
- Problem with youre file is that you have overlapping geometry
crossing the revolve axis (center of the inside).
Try to keep things simple at the beginning.
Also: as long as youre designing the shape just model the visible
surface and avoid having to thinwall that difficult 'indent'.
If this is a ceramic cup ,wouldn't the visible surface be enough
for moldmaking anyway ?
Hey guys and girls
Quick question. I have done all the tutorials solid thinking offers and have started my attempt at working through the user manuals. Does anyone know of any online tutorials or courses one could do to improve their skills. This is a newish program for me but i think its awesome. I have had great results using this program so far but i want to keep learning. Any help would be appreciated.
Thanks
Here is a list of learning material you can use.
Help on line:
If you open the help on line of solidThinking from the menu, you will find
the 'Tutorials' section with 3 tutorials: Getting started, Teapot and Chair.
I also contain details for any existing tool and function.
Tutorials & Manuals:
http://www.solidthinking.com/Navigation.aspx?top_nav_name=Support&item_name=tutorials
At the bottom of the page you also find the 3 reference manuals
and the Training course manual that is the most recommended learning tool.
Tips and Tricks:
http://www.solidthinking.com/Navigation.aspx?top_nav_name=Support&item_name=tips_and_tricks
Online Learning:
http://www.solidthinking.com/Navigation.aspx?top_nav_name=Support&item_name=online_learning
See It:
http://www.solidthinking.com/demos/demos.aspx
There are 5 sections in the bottom half of the page
where you can find many videos that you can also stop
and use as tutorials.
