Hi, I can't seem to run the Optistruct solver because it cannot run element cleanup. I am new to Hyperworks application and do not know what is wrong with the particular element.
Thanks for the help.
Here is a better picture
Can you please post the '.out' and '.stat' file of your FEM problem?
To solve this, you can either remesh the elements or turn off the element quality check.
To turn off element quality check, Go to Analysis page>> Control Cards>> PARAM>>CHECKEL>> NO
